What sort of gearing should I be looking at for the Forest of Dean if I go there with a single speed?
Thanks!
32:16 should be fine
don't be a fool,you'll surely die.
Just what's normal for you. Nothing too steep up or down.
32:16 is fine.
My friend rode a singlespeed there, i thought we'd have to call out the air ambulance- get some gears on there!
Is your friend weak?
I wore my lycra when I rode in the Forest of Dean.
Same gear as I wear everywhere else.
I [i]saw[/i] MTG in the FoD; for goodness sake don't wear the same gear as him 😯
I use 32:18 but then I'm over 50, over 16 stone, and over here.
Same as you'd run wherever you normally ride.
Run what you brung is the law.
32:14 is decent for there.
💡 i can confirm that a 57" gear made my knees ache for a bit after i rode there
I use 34:17 seems to be ok and I ride there quite often.
(It's 2:1, should use 32:16 but it's all I had in the shed !)
Ok, thanks!
I'll stick with my current 52" of single geared goodness!
nothing wrong with 32/18 hello pete
I did the SSEC last year in the FOD and used 31 X 16. Fine...
I reckon you are all too low. I use 42/18 on my SS Cx. And thats 700c wheels. I can't pedal up the steeper down hills but I can do the FODCa trail ok. Surely with SS you are never going to have super low grannies so the odd push is inevitable. Equally I spin out on my gears.
I must admit to hating twiddling and standing on climbs.
I am a near 13 stone 5'6" slob with 2 knackered knees and a dodgy back.
Funnily enough my knees like the bigger gears. its spinning that screws them.
Anyway run whats there. Bung another free wheel if if you must.
My friend rode a singlespeed there, i thought we'd have to call out the air ambulance- get some gears on there!Is your friend weak?
Yes he is- a bit tubby too.
Luke, the penny has just dropped and realised you're on a 29er, you'll be wanting 32:18 and not 32:16 then! Especially if you going to be following me;-)
Don't worry - I'm on 33:18 which is about the same as 2:1 on a kid's bike!
Sheldon - thanks again for taking us round the Forest of Dean. Had a great time.
I daren't put up a picture of any people for fear of falling foul of the A&A rules, and pictures of bikes have been done. So just a picture of some leaf litter. I think I'm safe with that:
