Flying with air sho...
[Closed] Flying with air shocks and forks
Whats the score with flying with a bike in the hold if its got air shock and forks ? Previously I've let most of the air out of each in the fear that the air pressure might blow the seals out of either during flight. I think I've even let my tyres down in the past.
Posted : 21/06/2010 6:58 am
The holds are pressurised so you don't need to deflated either.
Posted : 21/06/2010 7:00 am
Posted : 21/06/2010 7:01 am
Is this a game?
Posted : 21/06/2010 7:36 am
It's a minimal pressure difference at 33,000ft anyway, just a few PSI.
Does the pilot let his tyres down? I think not........ ๐Ÿ˜‰
Posted : 21/06/2010 7:42 am
Cabin and hold pressurised to between 5000ft and 8000ft.
Posted : 21/06/2010 8:18 am
even if you were flying in space, 15 psi wouldn't be enough to cause a problem!
Posted : 21/06/2010 8:32 am
air pressure is 15psi (thereabouts) at sea level.
if you took your bike into space, it would only have the same effect on the seals as adding 15 psi with a pump.
dammit! simon is too quick - i doff my cap, etc.
Posted : 21/06/2010 8:34 am
Cool - I'll leave all well alone then. Thanks chaps ๐Ÿ™‚
Posted : 21/06/2010 11:17 am
