Flow rims with yell...
[Closed] Flow rims with yellow tape but no sealant
Should this work with tubeless tires? Seems to be leaking from the valve stem...
Posted : 12/11/2009 5:54 pm
No you will need the liquid sealant to plug the pores in the tyre (when they are a non UST tyre) and the valve.
Posted : 12/11/2009 5:56 pm
I can inflate them easily but then they go down after a little while, with tubeless or non-tubeless tyres.
Posted : 12/11/2009 5:58 pm
My 355s with yellow tape didn't seal until I put sealant in - they leaked around the valve. Been a few months now, still perfect.
Why would you want to run tubeless without sealant anyway?
Posted : 12/11/2009 6:02 pm
Yeah I don't get that either
Posted : 12/11/2009 6:16 pm
It's the thought of mucking about with sealant that's stopped me going tubeless up to now.
I hate sludge, slime, snot etc.
Posted : 12/11/2009 7:11 pm
I find the sealant to be annoying. I do think it's easy enough to set up, but for some reason I change tires a lot, and I feel that has quite a lot of extra work. There are no thorns here requiring sealant as a back up, I'd rather just carry a tube in my back pack (I guess I'd do that even if I had sealant).
I also thought it was strange that it leaked from the valve stem, you would imagine that would be easy to get right? I recollect my Shimano XT wheel set having a seal on the inside and outside, this one only had one on the inside.
Would a rimstrip added to the yellow tape make a difference? Tires are LUST highrollers if it makes a difference.
Posted : 12/11/2009 8:29 pm
