Flat spots - can th...
[Closed] Flat spots - can they be undone?
A mate has flattened his rear wheel and was told he needs a new rim. Mavic X717 silver a couple of years old, used with Magura H33 IIRC. SO, does he need a new rim or is there a way of un-flattening the spot? The spoke directly there was loose by some 3mm, I don't know if it makes any difference though.
Posted : 27/01/2010 10:26 pm
if it is just a bit out of round / gone eggshaped you can sometimes true it out. If the rim is actually bent so as to be flat in one area then a new rim is needed.
Posted : 27/01/2010 10:30 pm
It's out of shape, properly flattened with the rim's profile "improved" on some 3 inches.
Posted : 27/01/2010 10:31 pm
Fubared
Posted : 27/01/2010 10:32 pm
Good, can't be bothered fixing them and he can afford new wheels easily ๐Ÿ˜‰
Posted : 27/01/2010 10:51 pm
I have improved a properly flatted rim but it did involve multiple blocks of wood, releasing the spoke tension and beating the rim back into shape. Not recommended and can easily split.
Posted : 27/01/2010 11:09 pm
