Fitting tubeless ty...
[Closed] Fitting tubeless tyres with an inner tube
[#4521455]
Right, I've bought some wheels with tyres 2nd hand and it turns out they're tubeless ready–both the rim and tyres. I'm not bothered about using them tubeless so I want to fit a new inner.
Thing is, despite knowing the tyre came off the rim, I can see no way it's possibly going back on! I've got it on one side, and about 3/4 on the other and no the bead forms a straight line across the last bit of rim. I've tried everything I can think of and it's simply not possible.
Is there some sort of trick I'm missing?
Posted : 02/11/2012 8:56 pm
Make sure one side of the bead is in the centre channel all the way round
Posted : 02/11/2012 8:59 pm
tubeless it and keep the tube as a spare in your camelbak if you ever need it.
Posted : 02/11/2012 9:02 pm
They can be really tight- try using a bit of soapy water to lubricate it a bit.
Posted : 02/11/2012 9:03 pm
Right, someone has definitely switched my tyres for ones slightly too small for the wheels. There is categorically no way these can fit.
Posted : 03/11/2012 12:05 am
It's all in the technique.
Are you doing the bit of bead around the valve last?
Posted : 03/11/2012 12:11 am
 br
Just use a big pair of tyre levers to get them on, oh you can't. For some reason you want to use a tube... 🙄
Posted : 03/11/2012 12:13 am
