Fitting SRAM 11 spe...
[Closed] Fitting SRAM 11 speed cassette to Hope XD driver
[#7257868]
cassette doesn't seem to go all the way onto the bottom of the grooves on the freehub - there's about a 3mm gap behind the cassette
is this normal?
thanks
Posted : 10/08/2015 9:58 pm
Has the lockring bottomed out on the axle end cap? You need an xd specific end cap for the drive side or get to file out....
Posted : 10/08/2015 10:20 pm
Lube, lube and more lube. Then it will slide on, says the same in fitting guide. Without it it struggles to bottom down, also makes removal easier
Posted : 10/08/2015 11:14 pm
Yep make sure there is lots of something like copper grease on there. Remove the end cap as well or the lockring tool will most likely bottom out and could wreck the lockring.
Posted : 11/08/2015 7:51 am
it's on! more lube and more oomph
just wondered if it had to be aligned in some way
Posted : 13/08/2015 10:00 am
That's what she said....
That's what I said back
Posted : 13/08/2015 10:08 am
Posted : 13/08/2015 2:47 pm
