Fitting FSA Carbonp...
[Closed] Fitting FSA Carbonpro seat post ????
[#2509864]
I'm just about to fit a FSA Carbon-pro seat post to my Merlin Malt 1 Frame using a QR clamp. Is there any need for prep of the frame or post to fit correctly..ie grease, lubrication etc?
Cheers in advance
Andy
Posted : 26/02/2011 9:14 pm
I have the same post. I found the best method is to insert the post into the seat tube, adjust to appropriate height, then tighten clamp.
Eerily simple really...
Posted : 26/02/2011 9:17 pm
It's just that i have heard differing stories when using a cabon seatpost. Some provide & say use some sort of 'goo', some say grease and other recommend going on dry 🙂 Just wantted to know which is the prefered method.
Andy
Posted : 26/02/2011 9:23 pm
Dont use grease - it softens the resin in the post and causes it to bond the post into the frame. Use carbon paste instead.
Posted : 26/02/2011 11:42 pm
Yep - carbon paste. It "grips" a bit, so you need less pressure from the clamp.
Posted : 27/02/2011 12:00 am
