Fitting a star fang...
[Closed] Fitting a star fangled nut...
[#2683824]
...[u]without[/u] them special tools what helps you do it. Any tips?
I've tried lining it up and smacking it with a hammer but that didn't work so well.
Cheers in advance
jon
Posted : 22/04/2011 8:32 am
Get a long bolt, screw that in, whack the top of that. Do it straight.
APF
Posted : 22/04/2011 8:42 am
As above, though the special tool does work very well.
Posted : 22/04/2011 8:46 am
+1 and the special tool means you don't accidentally whack your hand 🙂
Posted : 22/04/2011 10:06 am
 jonb
I've done the long bolt method with mixed success. Sometimes it's easy and other times it's a real pain. I think the internal diameter of steerers varies.
I assume it's urgent? IF not just buy the proper tool <£10 from Superstarcomponents which is probably significantly less than the cost of the forks?
My LBS charges £5 including the new nut, maybe your LBS is a good alternative?
Posted : 22/04/2011 10:07 am
I bought a long threaded bar a washer and nut using them pull the star nut into the steerer from below. Fingers all intact
Posted : 22/04/2011 10:33 am
Great idea Kona tc
Posted : 22/04/2011 11:13 am
i use a piece of shortened broom handle it works fine for me...but sweeping the drive gives me blisters now!
Posted : 22/04/2011 11:25 am
Thanks for the suggestions.
It's not urgent (given that it's taken me a month to find the time to get this far!).
Might have a look at getting the tool. I'm sure I'll use it more than once.
jon
Posted : 22/04/2011 2:58 pm
