How loose should the preload be on the non drive side crank arm? is there a torque setting or is it just "finger tight"?
Posted : 01/08/2009 5:33 pm
use the little sombrero-shaped tool and tighten it as tight as you can with your fingers. ( ~5nM ?)
Posted : 01/08/2009 5:34 pm
get a durace metal one looks nicer, yours come loose on your 22mile ride, go careful on the allen bolts as easy to strip theads
Posted : 01/08/2009 6:12 pm
It is fitted as per hope video teeeeeray and i used my torque wrench (backed off when finished - yes :))
Posted : 01/08/2009 6:35 pm
always back it off you will damage the spring
Posted : 01/08/2009 8:31 pm
have done and always will do my jedi knight
Posted : 01/08/2009 8:41 pm
