Fitting a clutch re...
[Closed] Fitting a clutch rear mech.
[#7215746]
Is there anything different to a conventional mech?
Mech is on the bike and I can push it from small to cog to big cog with no chain on.
It is a used 10 speed 786 XT mech and am running it with a XT 9 speed shifter.
With it all connected up the cable will only pull it enough to span 4 cogs. What am I doing wrong?
Everything worked perfect with the previous mech.
Posted : 25/07/2015 9:53 pm
Chain too short?
Posted : 25/07/2015 9:56 pm
You'll need a shimano 10spd shifter for it to work.
Need a 10 speed shifter and sounds like your cables either not tense enough, or shot.
Posted : 25/07/2015 9:59 pm
Yep different pull ratios. You'll need a 10 speed shifter and 10 speed casette. Like wot Simon said.
Ok will fit it to my 10 speeder.
Is there a clutch mech for 9 speed?
Posted : 25/07/2015 10:02 pm
No
Posted : 25/07/2015 10:03 pm
No
Not totally true - Sram shifter will work 9 spd with Shimano mech with a bit of fettling.
Or you can use a thumbshifter on friction. This works suprisingly well, I'm currently using a 9spd thumbshifter on friction, with an SLX Shadow+ 10spd mech, on an 11-28 8spd cassette. Works really well!
Posted : 25/07/2015 10:14 pm
