Fitting a 40T ring ...
[Closed] Fitting a 40T ring - this ghetto fix OK?
 hora
[#7549143]
My cassette doesn't split to enable removal of the 17T ring so I found an old spacer and removed 2xsmallest rings instead. Apart from obviously losing my two lowest gears is this OK? Sanity check really..
Posted : 01/01/2016 6:31 pm
Why remove 2 if your only adding 1 ?
Posted : 01/01/2016 6:36 pm
It's probably ok. But also silly.
Posted : 01/01/2016 6:43 pm
What's the point? Run a smaller chainring on the front.
Posted : 01/01/2016 6:53 pm
Sanity check
Just read some of your old posts and decide for yourself on that front. 😉
Posted : 01/01/2016 6:55 pm
 hora
Doesn't work- I can't stop shifting into the spacer at the end. Humphh. Just wait until I have to refresh the drivetrain/cassette next.
Posted : 01/01/2016 6:57 pm
You do you know that you can adjust the cable to limit movement don't you?
Posted : 01/01/2016 7:05 pm
You can get a 13t lock ring and keep a smaller cog .
Wind the hi & lo mech stops so the mech "stops" then put the shifter in the smallest sprocket, thread the cable up, and Fanny's your uncle's wife.
Job done.
Posted : 01/01/2016 7:22 pm
Just Dremel the pins out of the cassette and stack the sprockets the way you need them.
Posted : 01/01/2016 7:27 pm
Buy a less shit cassette
Posted : 01/01/2016 7:34 pm
 poah
use a 13t lockring from absolute black.
Posted : 01/01/2016 7:47 pm
Swap the 40t thing for a 30t n/w chainring, refit original shit cassette and mtfu.
Posted : 01/01/2016 8:45 pm
Haven't you effectively got less range by dropping the lower two sprockets?
Posted : 01/01/2016 8:47 pm
Possibly not as he is raising the range with the 40 and lowering it with the removal of two cogs - essentially shifting the range to [s]softy[/s] more granny and less top end
Also please just adjust the mech to stop the shifting.
Posted : 01/01/2016 9:03 pm
As said above - Dremel the pins and the cassette should now be splittable. It's only the heads that need to be removed.
Not sure why you removed 2 sprockets when you were only adding one though...
