Fitting 1 1/8th&quo...
[Closed] Fitting 1 1/8th" Stem to 1" Fork Steerer - DIY BODGE REQUIRED
OK I'm putting together a TT Bike for an event tomorrow. The bits arrived yesterday but the shim that should have (presumably) been with it didn't.
The stem (alloy)is for a 1 1/8th" steerer but the forks have a 1" steerer (carbon). THe stem is part of a one piece aero bar set-up so I can't just swap it out.
Can't get a shim from any of the local bikeshops and although I can get one off the web for £3 I can't get it TODAY.
Any ideas? Can you get 1/8th" thick washers with an internal 1" diameter anywhere?
Posted : 26/02/2011 12:23 pm
Where are you based?
Posted : 26/02/2011 12:32 pm
If there's a Halfords near you could try one of these,
[url= http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_568679_langId_-1_categoryId_230508 ]steerer adapter[/url]
I think they come with 2 shims that you'll be able to use.
Posted : 26/02/2011 12:37 pm
The missing shim (not inside the stem clamp is it?) is probably just a rolled piece of ali sheet. Thickness-wise you need to add 1/16th (or 1.5875) to the steerer to take it out to 1 1/8th, which handily is a pretty good match for 16 gauge ali. Where abouts are you based - got loads of off-cuts which are just the job here in sunny Macc!
(Usual caveats about death resulting from bicycle bodgery advice gained from internet weirdos apply)
Posted : 26/02/2011 12:59 pm
you need a shim 1.5875 mm? the only thing i can think of that might be available is a seat post shim.
or make your own from soft plastic (cd box, bucket) guessing you wouldn't want to use coke can shims on a carbon steerer.
fit plastic shim, tighten ad the check it doesn't slip. wouldn't want you turning one way and the bike going another.
Posted : 26/02/2011 1:04 pm
I've got one.
I'm in derbyshire though.
Posted : 26/02/2011 1:25 pm
if your anywhere neer bracknell have a spare shim
Posted : 26/02/2011 2:11 pm
Thanks for all the replies everyone.
I'm actually in Aberdeenshire 😮
My internet crashed a few mins after the post and didn't get fixed (by 2 engineers) 'til monday night.
Anyway, went along the lines of splitlip's idea and got a steering adaptor, which had shims with it, and got the bike up and running i time for the event.
Cheers for all the suggestions 🙂
Posted : 01/03/2011 8:59 am
