Just started using ezTOUR with a GPS logger thing for rides. The software plots the route on a map. It is set on maps.google.co.uk but you can set the background map to any map you like. Since Google is not too good for what I want, I'd like it to be on OS maps, 1:50k or 25k.
Anyone know how to do that?
C
Assuming it saves the ride as a GPX track, you could use it on something like wheresthepath.com.
You can import GPX files into "WheresThePath", and it shows the route on both OS Maps and google earth photo at the same time. I think they have a limit to the number of OS maps they can reproduce in a day, so it's better earlier in the day before the limit is used up.
http://wtp2.appspot.com/wheresthepath.htm
Ta, I'll try that
C
