Exposure Strada Q
[Closed] Exposure Strada Q
[#8355789]
Hello chaps & chapets
Just wondering if it is still worth buying a NOS Mk5 for £145 from a LBS?
Or should i just spend the extra on the Mk6, would like the 1200L but sadly I missed the Wiggle offer and can't quite warrant the extra....finding it hard though....
Other options are a Gloworm CX from another LBS or Moon Meteor Storm Pro from Online which seems to have a similar beam pattern with more Oomph!
Will be used on unlit Cornish coastal roads.
Opinions much appreciated.
Posted : 20/02/2017 6:42 pm
I'm running a mk2. I'd jump at your nos offer. It's a great light in all its guises. I can coax about 2 and a bit hrs of use out of mine. The newer ones will give you a longer burn time. You don't need more than 800 road focussed lumens, but longer is good.
Posted : 20/02/2017 9:33 pm
TiRed
thanks for that info, everyone tells me Exposure are the mutts but the tight Cornishmen in me is finding it hard to warrant them...... the C&B Seen City Slicker is more pocket friendly...... will probably sneak out and buy the light when the misses isn't looking...
Gutted I chickened out on the 1200Lm Mk6 at £166 or whatever it was....
Cheers, Steve
Posted : 20/02/2017 9:50 pm
Evans have 30% off of the strada 1200 again 🙂
with mine even on low it's bright enough and oncoming cars still flash you so the mk5 will do the job.
Posted : 20/02/2017 10:07 pm
 Haze
Have the 1000 lumen, even in low it's more than enough.
I run it on medium for the entirety of most of my night rides purely because it can.
Posted : 21/02/2017 8:18 am
Deed is done, misses isn't happy but at least I will be seen....and I can feel a little bit good about myself for using a LBS while buying British lights (does it count when they are discounted...)
[url= https://c1.staticflickr.com/3/2197/32991156126_60997d7b9e_z.jp g" target="_blank">https://c1.staticflickr.com/3/2197/32991156126_60997d7b9e_z.jp g"/> [/img][/url][url= https://flic.kr/p/SgjijE ]IMG_20170221_130455_374[/url] by [url= https://www.flickr.com/photos/2strokesteve/ ]Stephen Williams[/url], on Flickr
Cheers, Steve
Posted : 21/02/2017 2:19 pm
