Exposure stem fit b...
[Closed] Exposure stem fit bracket
[#10681130]
Anyone got one? Another interface with a tree last night broke the standard bracket for my Six Pack. Standard brackets always been a bit crap IMO, quite like the idea behind these and mounting the light central out of harms way below the stem appeals. Might be too low though?
Posted : 21/06/2019 7:19 pm
I have one, but the actual interface between the light and the clamp when fitted is quite loose so it wobbles a fair bit, can’t tell if it is wear and tear or a poor tolerance.
Posted : 21/06/2019 7:29 pm
Was it always like that from new? Exposure have excellent CS rep, I'd contact them.
Other than that how is it?
Posted : 21/06/2019 8:19 pm
It’s grand, keeps the light in a nice central position... it’s two years old and didn’t cost much in the first place which is why I am hesitant to bother them. I’d be hesitant to use it on an MTB though, I use mine for audax stuff
Posted : 21/06/2019 8:20 pm
Ta. Do you run it over or under the stem?
Posted : 21/06/2019 8:23 pm
Under, but it’s a 100mm road stem
Posted : 21/06/2019 8:32 pm
Something wrong with that, I race mine with a reflex on and it's rock solid.
[img] [/img][/url]
Edit to say: exposure replaced a standard bar clamp that had died from old age at twentyfour12 for free so give them a shout. All my exposure brackets are rock solid (bar and this stem one that I had to get as the new bike had 35mm), sounds like a duff one.
Posted : 21/06/2019 8:59 pm
I'm guessing these come with M5 bolts? My Syntace stem has M6 so prob not going to work if the spacers etc are also sized for M5
Posted : 25/06/2019 7:38 am
They are M5.
And on megaforce stems the bolts are also spaced too widely, which means the Exposure mount won't fit.
Posted : 25/06/2019 8:08 am
Thought the spacing was on the limit. Thanks for confirming.
Bah.
Posted : 25/06/2019 9:03 am
