I have just bought some hope mini IS mounted brakes on here and I need adaptors. I have IS fitting on forks and rear of bike. Running 160 front and 140 back.Do I just need a Hope Mount Adaptor IS to IS +20mm at the front,and the rear 140 bolts on directly, using shims to align?
160 and 140 should bolt straight to the fork and frame without adapters as long as it is all IS to IS.
It all depends on what calipers you have. For IS hope calipers, they do different models for different rotors.
The same model of caliper will fit a 20mm bigger rotor at the front than the back.
If you bought yours from this ad:
http://www.singletrackworld.com/forum/topic/more-clearout-santa-cruz-blur-classic-framehope-avid-etc-etc-all-must-go
Then they should just bolt straight to the frame and fork and take a 160f and 140r rotor with no adaptors. Adding the adaptor you mention would allow you to fit a 20mm bigger rotor than currently (eg 180f, 160r)
If they're the older hope brakes which are direct IS mounts without an adaptor then the caliper number will determine what size rotor you need.
Clubber, yes that's them.
Where is the caliper number on it?
On the back of the caliper just above the lower mount hole - should be 5 for rear 140mm IS
http://www.hopetech.com/technical/tab_fitt.htm
Front 5 165mm
rear 5 145mm
but the rotors are mono-mini 160 and 140mm? all OK?
Yes, that'll be fine - that Hope link refers to the older discs that were 5mm larger.
Whoopee!
All I need now are shims and I see CRC are out of stock 🙁
got any spare to sell snaps?
I'd pop some in the post for free but I'm not back home until sunday.
Your LBS ?
Sounds nuts, but I really do not have a LBS.
I am in no rush, Snaps email me your paypal and I will drop in £3 to cover the hassle. Many thanks - I would get some stainless M6 washers, but I am aware these come in the waffer thin variation for that perfect alignment.
