Excuse my lazy goog...
[Closed] Excuse my lazy googling - can a 12mm DT Swiss Centrlock 350 convert to 15mm?
[#12378005]
I have a lovely set of handbuilt Pacenti disc brake wheels sitting in my garage doing nothing, so I figured I'd try fit them on my Trek Superfly. I only use it for gravel duties occasionally so I'm happy enough using a relatively lightweight aluminium rim.
I just can't figure out if my current centrelock DT Swiss 350 hub will convert to a 15mm through axle? It's set up for a 12mm currently but I don't know if the internal bore of the bearings would accept a 15mm axle? Has anyone done this?
Ta
Posted : 11/05/2022 9:01 am
Edit: ignore! My previous googling must have been exceptionally lazy, conversion kit apparently available from DT 🙄
https://www.dtswiss.com/en/support/product-support?matnr=H35PACDXR24SA8673S
Posted : 11/05/2022 9:06 am
