Evans Suspension Se...
[Closed] Evans Suspension Service
[#4396209]
Has anyone used the service and how good was it with the turnaround.
The price it says for the a Fox Float RP2 is £45. that is almost have the cost of Mojo or TF.
Is it anygood?
Posted : 24/09/2012 9:02 pm
I would check what the Evans service consists of compared to Mojo and TF. Might be a reason it is so cheap.
Edit.
Sending my shock to the pros or to Evans is a no brainer for me.
Posted : 24/09/2012 9:09 pm
It's just an air can service. Not a full service.
Posted : 24/09/2012 9:14 pm
From there website,
"Our suspension experts can provide air can services' on Manitou, FOX and RockShox air sprung rear shocks.
The service includes:
Full strip down, inspection and cleaning of the air canister
New seal kit fitted
Shock lubricated
Re-building of shock
Re-pressurisation of shock
Your shock will then be returned along with any replaced parts (for your inspection) and a technical report detailing the work undertaken.
All shock services are charged at a fixed price of £45. Postage of £7 applies for shocks returned to you directly by our courier (no charge for shocks shipped to our stores for collection).
Should any other parts need replacing (such as bushings). Our suspension technicians will contact you and advise on any additional parts needed and inform you of any extra labour charges before the work is carried out.(in most cases there is no additional labour charge). We will contact you for permission before fitting any additional parts."
JUST READ THE AIR CAN SERVICE PART. I DO THAT MYSELF. Sorry peeps for the post. the shock needs a full service.
Posted : 24/09/2012 9:15 pm
 LoCo
Just an air can service, have seen another company charging £65 for the same thing 😯
Seal kit is less than 20 quid and is a 5 minute job once you've done it a couple of times 😉
Posted : 24/09/2012 9:23 pm
