ESI grips not stick...
[Closed] ESI grips not sticking
[#6769846]
I've got a couple of ESI chunky grips. The yellow ones currently on the bike have always stuck fast with window cleaner but the black set have always moved. Tried window cleaner, hairspray and and a combo but no joy. Just got a set of carbon bars and want to put the black ones back on but not if they move. Any ideas? Renthal grip glue doesn't get good reviews on CRC, maybe clear silicone? Also don't to use anything which might compromise the carbon. Ta now.
Posted : 10/01/2015 9:16 pm
I just stick mine on with IPA (disc brake cleaner). Never budged.
Posted : 10/01/2015 9:17 pm
 rhid
I've used concentrated screen wash with great success.
Posted : 10/01/2015 9:19 pm
Forgot to say I've tried IPA on them without success but thanks. Will give the screenwash a go
Posted : 10/01/2015 9:22 pm
Quite a lot of the things that people suggest can be counterproductive- like, some window cleaner things can work, others leave a slippy residue, totally the opposite of what you want. So if I was you i'd get everything super clean and start again.
Posted : 10/01/2015 9:24 pm
 akak
My current pair aren't sticking either, previous 2 were okay. I wonder if they have become a slack fit as they get old.
Posted : 10/01/2015 9:26 pm
WASHABLE. INSTALL/REMOVE WITH RUBBING ALCOHOL- WINDOW CLEANER- COMPRESSED AIR
Posted : 10/01/2015 9:27 pm
I've had good success with alcohol gel hand-sanitiser stuff - that evaporates off well.
Although - I have had a pair go "slack" over time - but most pairs I've had have been ripped to shreds long before then!
Posted : 10/01/2015 9:37 pm
Spray glue (3M mounting glue) is ACE, any WD40 or GT85 dissolves it away to remove them.
Posted : 10/01/2015 10:32 pm
Never used anything and they are fine, both bikes
Posted : 10/01/2015 10:35 pm
I don't use anything. And they only move when death gripping. Pig to fit though
Posted : 10/01/2015 10:37 pm
 ton
good old fashioned spit used to install mine, never had a problem with any of em slipping.
Posted : 10/01/2015 10:42 pm
Sounds like they could be contaminated with release agent, the release agent stops them sticking to the mould, usually silicone lube, try washing them in soap and water.
Posted : 10/01/2015 10:58 pm
Have tried the double concentrate screen wash. They never held from new but maybe they were contaminated with release agent, maybe they were just slightly out of spec. They have a fair few chunks out of them though so if they don't hold might be time for a new set. Still always seem expensive for what they are but love the comfort. Thanks for the suggestions y'all.
Posted : 11/01/2015 12:01 am
Spinning like tops today. Time for a new set methinks.
Posted : 11/01/2015 6:05 pm
I've always used hair spray and never had a problem.
Never tried to remove and reuse a pair though. Only take them off if they are mullered so I just cut them off and put on new ones.
Posted : 11/01/2015 6:17 pm
I just don't see the appeal of these grips and this, (and the fact that they look tatty and raggedy-ass after a couple rides) completely puts me off
Are the benefits worth it cos im in the market for new grips
Posted : 11/01/2015 6:35 pm
I have used just water to put them on then leave for a day. Never slipped even in torrential dusk til dawn rain a few years ago
Posted : 11/01/2015 6:50 pm
Been through about 4 pairs of these grips and only ever used IPA, they only get loose when the ends are torn and damaged and they have been very wet, in my experience.
Posted : 11/01/2015 6:57 pm
They do get damaged quickly, the fixing can be a pain and they don't look all that but by crikey they're comfortable. I have knacked wrists and the difference these made (along with the shape of Renthal bars) is huge so for me they're worth it.
Will try water /spit on the next pair.
Posted : 11/01/2015 7:09 pm
Wow, mine never move a mm on my carbon bars. But I did blow them on dry with a compressor. Maybe that helps?
Got three pairs, green and yellow no problems with window cleaner or IPA but black pair were never any good. Just a duff pair more than likely
Posted : 11/01/2015 7:17 pm
