12mm axles...
[Closed] 12mm axles...
[#6769818]
Have I got this right?
Three standards, Maxle light, Fox/Shimano e-Thru, Syntace X12. Major difference between them is the thread pitch, and that for RS one dropout has to be threaded, for F/S there is an axle bolt the axle screws into (which isn't part of the frame as such), and for Syntace it's as for RS but there's a pinch bolt?
Posted : 10/01/2015 9:15 pm
[img] https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRMeKuvkjt_2FN8pfB6EDkmmcDICLJ_5ohYFScEhPpeiv7aJayVZA [/img]
syntace x12 i think is a 135mm
rs 12x142mm
shimano 12x142mm
Posted : 10/01/2015 9:26 pm
It's 142mm according to their (otherwise thin) product page.
Those pics are useful - thanks.
Posted : 10/01/2015 9:30 pm
I guess its changed again.
I remember having to make spacers up when i had syntace x12 hope adaptors before i got the correct maxel light 12x142 adaptors
Good luck getting the right ones!
Posted : 10/01/2015 9:38 pm
I think there are two Syntace 12mm axles...
Posted : 10/01/2015 9:42 pm
and there is the dt swiss version you have over looked
Posted : 10/01/2015 9:46 pm
Isn't that just a rebadge of one of the others (?Syntace) using an RWS axle?
Posted : 10/01/2015 9:55 pm
As far as I'm aware Syntace invented the 142x12 standard and called it X-12. IMO it's what 135 standard should have been in the first place, it's a much better design.
Everything else is a copy/variant of that. Syntace and DT Swiss do two x-12 axles one uses an Alan key to tighten the other requires no tools.
I think they are all slightly different maybe so as not to infringe Syntace's original design.
Posted : 10/01/2015 9:59 pm
The RS one looks like a real plaster - to use it as per instructions there a lot of faffing with torque wrenches. E-Thru makes a lot if sense IMHO - axle nut means there are no frame threads to strip...
Posted : 10/01/2015 10:06 pm
Afaic you just tighten it by hand, they market it as requiring no tools. That's what I used to do and the clever design kept it tight, don't know how it worked (my experience is from a 2009 cube stereo with DTSwiss x-12, there was nothing else at 142 at that time )
Posted : 10/01/2015 10:15 pm
X-12? RockShox [url= https://www.sram.com/sites/default/files/techdocs/gen_0000000003373_rear_maxle_lite_installation_specifications.pdf ]fitting instructions[/url] need a torque wrench. I doubt many people bother with step 6, mind...
Posted : 10/01/2015 10:29 pm
Sorry I thought you meant the DT Swiss one (RWS) 😳
Posted : 10/01/2015 10:36 pm
And Canyon use a double threaded axle on the Spectral, both ends are threaded using a fine pitch thread.
Posted : 10/01/2015 10:53 pm
DTSwiss was the 'platform' for the original Syntace X-12 on the majority of 142x12 bikes (cube in my case back in 2009). I think it was essentially Syntace X-12 with a DTSwiss branded and designed axle, as the one pictured above altho mine looks like this, slightly different handle:
slightly different handle, but essentially the same axle/thread. The E-Thru and Maxle came later I think, plus now Mr Hoppy's version on the theme, it would seem.
Posted : 11/01/2015 1:20 am
I'm only familiar with X-12. As already said, there were two axles available. DTSwiss did a 'tool free' axle (the one I pictured), Syntace did a slightly cheaper alan key version
It's all moved on now tho, so many different versions on the same theme.
Posted : 11/01/2015 1:41 am
