Enduroguard on 29er 130mm rockshox rev, 2.2 Hutchinson squale tyre - got completed blocked with the plasticene mud around here (S.Cotswolds) this stopped the wheel, which to the side and I fell over (clipped in moment!). Cleaned it out, but 50yd same problem, wheel hardly moving, so I took the enduroguard off, rest of ride fine.
So Enduroguards are fine when mud is wet, but not when it is sticky. Crap really so have taken it off.
Go quicker. It's clogging because you're not spinning the wheel quick enough
Clearly you're not being Enduro enough for them to work.
They're just not good for bad mud, I reckon the main reason you don't hear it more often, is that most people don't ride in bad conditions. Sort of like "You can fit a 2.8 tyre but it's tight". Comes up a lot at races when people end up riding stuff they'd normally just avoid. (lots of it at last year's scottish EWS)
I like the wee guards for better weather, but when there's actual mank to be dealt with a crown guard is just miles better- better at mudguarding, impossible to clog.
Suffered same dilemma at ews last year, need to keep wheel turning to stop it clogging ie dont use your brakes as much ๐
Sounds like the wrong type of mud
๐ฏ
Use mine around West Yorkshire, Peak District and we get wet sandstone grit, peat/moorland and regular forest floor matter and sticky wet mud, never had an issue with the rrp enduroguard neither have my mates, all year round
Damn it's been confirmed I'm just not enduro enough
Enduroguard on 29er
Wheel size error.
Had the same problem with a Muckynutz front guard. Not to the point of stopping the wheel but definitely slowing it down significantly. It was also piling mud up against the fork stanchions, amongst which I found several large, sharp stones. Luckily none had actually damaged the stanchions, themselves.
I still use it, but keep a close eye on it.
It's a bit better with fox forks IMHO. I had the same problem at Vallelujah last year, I tried to rip the thing off at one point. This year swapped from pikes to fox 36, with same enduro guard. Conditions this year were worse than last year in places, no issues at all with the guard clogging up. Looking st the crown, fox 36 just seem to have more clearance than pikes. Not sure if that's the same across fox v Rockshox.
Surely if it clogs against the guard it would clog against the fork brace?
The guard is both a funnel and a retainer, it scoops in more mud and helps keep it there as it can only escape out the front (usually when the fork crown clogs, mud gets pushed out the side and over the top). Some guards reduce the amount of clearance by a fair bit too.
If you know it's going to be muddy take your wheel out and spray wd40 or gt85 on the inside of the guard and it will stay clear for alot longer
Mine seems to do nothing at all.
I end all wet rides covered in mud, especially my face.
