Like it says. Bearing in mind I'm a proper shortarse & look like Don Estelle in (some) normal shorts.
'Sing Lofty!'
Yep, I do, they are sized on the small side for sure, particularly the inner shorts. I am 64 kgs and wear either 28's or 30's in normal trousers (most 30 in kecks are a bit big for me) I wear medium Hummvees and they are snug !!
Otherwise they are pretty good, loads of pockets and reasonably well made. I'd reccommend them
I had them for a while and the crotch area wore out. I now use the Singletracks which are far more durable IMO.
both singletracks & humvees quality has tumbled in the last yr or so.
I've been through 3 pairs of singletracks this yr & I can't be arsed to take them back AGAIN.
Gore for me from here on in... till they funk up
2 pairs now. The liners are a bit pants and they're very light. I've got a five year old pair that's only now showing signs of age (getting thin, pocket zips going). I find the legs a bit short so you should be fine.
As per most shorts I seem to try, the stitching wears through on the arse and they fall apart.
