Anyone got an Elite turbo of some sort that uses the Misuro B+ sensor?
I've just replaced the battery in mine (with a brand new Duracell piece) and my watch won't pick up the sensors now.
I've removed them from the watch and did a search for them again - it has picked up the Misuro B+ for Cadence and it tells me it has a found a Power sensor, but no Speed sensor.
When I start a session, it then tells me it is searching for the Power sensor and there is no detail showing about the Cadence - it looks like there was an initial detection but they aren't talking to each other.
Watch is a Garmin Fenix 6 Pro, turbo is an Elite Turbo Muin with the Misuro B+ sensor. Watch is about 2 months old and turbo is 3 years old.
I've tried different batteries and I've tried removing and repairing the sensor, but Speed isn't being found at all and the sensors that are found aren't reporting anything on the watch.
Wondering if anyone else has had this issue and if so, how it was resolved (hopefully not by replacing the turbo with a completely different one!).
Thanks.
Mines can be a bit flakey at times and sometimes needs re pairing. Especially if the apps I'm using have recently had an update.
Are you connecting via Bluetooth or Ant+? And have you checked the possition of the Misuro sensor is the same as before the battery was changed?
I use an Ant+ USB on a laptop and its pretty stable on that but Trainerroad will sometimes not recognise it. The solution was to un pair it in the app, restart the laptop, then re pair.
Some apps stopped working with it after an update but the next update fixxed the issue so It's probably not the turbo at fault.
Yeah, same position but the watch is newer. Looks like my watch isn't compatible with it.
Ant+ is working and watch detects 2 of the 3 sensors but doesn't report any activity.
Have managed to connect sensor to phone using Bluetooth and everything works on that, so I'm now thinking it is an incompatibility issue with watch.
