Edge 500 route scre...
[Closed] Edge 500 route screen
 2002
[#4827829]
I have run an Edge 305 of about 4.5 years and have never had any problems following a route I have done by following the line on the screen and have never had any problems. First ride today with the Edge 500 and all I had all ride was it either being to slow to keep up with the road I was on or more it kept saying I was off course when I was not then the screen either going blank and after a while coming back or 2 times I had to stop and re enter the course using the buttons. I have read some thing about it is a known problem since a soft wear up grade in 2010 . Has any one else got this problem or could it just be my unit.
Posted : 02/02/2013 10:44 pm
 2002
I have found a few bit on e web about this being a Garmin update fault and I wondered if there is any way to sort the problem I have other wise I am going to send it back.
Posted : 06/02/2013 7:58 pm
Mine is fine.
Posted : 06/02/2013 8:07 pm
Mine does it all the time. Garmin admitted it was a software fault and they have no timescale to fix it and couldn't offer any solutions. They wanted me to undertake a long winded diagnostics routine next time it happens. I asked if they'd pay me to become one of their software engineers, don't think they saw the funny side.
Posted : 06/02/2013 8:35 pm
Mine also does this.. it seems to do it less on courses created within the Garmin software (as opposed to imported routes) and higher scales.
Posted : 06/02/2013 9:03 pm
 2002
For some reason I did a master reset on my 500 and then tried the unit on a ride to work the next day and the unit has been transformed and now seems to be following the route ok and it only went off the screen for a few second 2 times. It now finds the sat-alights in about 10/15 seconds when I turn it on where as before it was taking any where up to 2 minutes to find them. Garmin got back to me the day after I did the reset and said I should do a master reset and thenup date it as well.
I have milled up a reach forward bar mount out of a light mounting and a bit of acetal plastic and it works very as I can swap it between bikes in seconds. I am going to make another one so it is a bit furhter forward and it is far better even 3 inchs forward of the bars as you do not seem to be looking as far down to see the 500.
Posted : 09/02/2013 7:02 pm
