The front one looks ok, but if that is aluminium or similar It's very bad idea to have those rough edges on it.
The rear one looks less good, too high and too long.
A few post back you posed the question:
Question. So. Does it matter where you position a mudguard as long as its effective.
Yes, if it could be more effective positioned elsewhere. It needs to much closer to the tyre, At the moment it's only keeping a small strip down the centre of your back un splattered, a sort of reverse Pepé Le Pew effect
[edit]
Just spotted the gear cables too. Not good, you want to route the cables so that they take the shortest smoothest line. you've added two tight bends where one wider curve would have been better.
it wouldn't surprise me to see either or both of these lurking in your shed/garage:
[url= http://1800recycling.com/wp-content/uploads/2011/08/cart-bike.jp g" target="_blank">http://1800recycling.com/wp-content/uploads/2011/08/cart-bike.jp g"/> [/img][/url]
[url= http://1800recycling.com/wp-content/uploads/2011/08/shoe-bike2.jp g" target="_blank">http://1800recycling.com/wp-content/uploads/2011/08/shoe-bike2.jp g"/> [/img][/url]
but i want one of these....
[url= http://1800recycling.com/wp-content/uploads/2011/08/formula-1-bike.jp g" target="_blank">http://1800recycling.com/wp-content/uploads/2011/08/formula-1-bike.jp g"/> [/img][/url]
Their good and work perfectly. Job done well.
At the end of the day its a homemade mudguard made from bits of plastic and cable ties.......thats not really the most exciting creation in the world - in fact more of a job than a creation. I could post a picture of me cleaning the bathroom on Saturday morning but I dont think people would be interested.
op, you ask for comments, here is my comments:
the front looks like it stops some mud, but also looks quite scary with the wide sharp bits near the legs
the rear looks like it needs mounting "a bit" lower where it will be more effective
give the guy a break -
valves and tyre logos line up and there is even colour coded valve cap.
Very effective and won't shatter if I flick a big stone or similar up at it.
Absolutely brilliant! 😆
The front section of drain-pipe/ guttering is an artery-severing, tendon and muscle sheering death trap! One sudden stop on that bike and you're going to be a brilliant toulouse lautrec impersonator.
Bullshit. They are not sharp. But it's a shame your eyesight isn't as sharp.
Yeah looks like it really works well judging by how much mud is on the frame.
how does the fork compress??
im not sure if i like the rear one or the front one the most.
front is much like a standard crud guard without the rubber section towards the headtube
the rear is taking the ass saver concept of saddle attachment, but thinner and longer, like its made from an sks chromoplastic
*goes back to check cables*
[i]how does the fork compress?? [/i]
I worried about that - the black forks brace must hit the 'guard after about 50% travel's been reached.
Provides extra damping! 🙂
Like I say, not mine. I don't use mudguards save for a a55saver on the back. I wouldn't want to use it but it's not really any different to those 'THE' ones I don't reckon. Maybe they sit a bit higher..
Mind you, if you look on the white forks behind you can see it sits within the crown. Unless you are regularly bottoming out your forks (maybe unlikely on most xc rides) then it probably wouldn't be a big problem..
[img]
[/img]
