e13 Tubeless Valves
[Closed] e13 Tubeless Valves
[#11992849]
I bought some of the e13 tubeless valves recently - because they looked like a good solution to occasional leaky valve issues.
I thought I would install them yesterday, but cannot for the life of me - unscrew them into the two component halves.
I’ve looked online - including e13’s own site and cannot get any clarity.
Anyone got any idea?
Posted : 09/08/2021 1:12 pm
I've been using them for a couple of years now, found them pretty simple to install and as far as I remember unscrewed easily by hand, sorry but I can't really say anything more helpful than that to be honest
Posted : 09/08/2021 1:50 pm
No worries - thanks for responding.
Posted : 09/08/2021 1:51 pm
It turns out that I just needed to hold the knurled ring firmly with pliers and unscrew the base.
I hadn’t wanted to do that because of marking the ring - but once you said that it just unscrews, I thought it was worth a shot.
Posted : 09/08/2021 1:56 pm
I vaguely remember using a 3 or 4mm hex key on the base to tighten the 2 parts together when fitting the valves, worth remembering as the correct size on my multi-tool was too short to reach into the bottom of the rim bed when I managed to destroy the E Thirteen tyre (thumbnail sized hole that wouldn't seal) on the rear wheel and couldn't remove the valve to fit a tube. I made sure 2 put a suitable one in the pack after that disaster
Posted : 09/08/2021 5:38 pm
Good tip - thank you!
Posted : 09/08/2021 8:05 pm
Looks like a new version is in the works https://www.pinkbike.com/photo/20760769/
Posted : 11/08/2021 1:48 am
