Ive got an exposure Dynamo hub with a revo light. I also want to use a b&m e werk usb charger to charge up a garmin while on longer trips. What's the best way to set this up? I've connected the e werk to the hub and that then charges the garmin no problem. The revo won't work on this setup though,only if it's connected straight to the hub. I've seen a few things about having a switch to toggle power between light and e werk. Is this what I need and if so what type and where from? Cheers
Posted : 01/04/2015 12:38 pm
Why not just run 2 cables to the hub and unplug the Revo when you want full charging power?
Posted : 01/04/2015 12:47 pm
As above, run in parallel. unplug revo connector at the light end when not required
Posted : 01/04/2015 2:19 pm
