DX P7 torch not wor...
[Closed] DX P7 torch not working
I have one of the MTE SSC P7 torches from DX. It was fine last year but I came to use it the other day after not using it for the summer and it doesn't work properly/at all.
I turned it on and it would turn on but then started to flash while in a none flashing mode. Jiggling it around sorted it out temporally. But now it's not turning on at all. It's like it has a loose connection.
I have recharged the batteries, I also noticed that the bulb unit was a bit loose on its threads so I've tightened that up a bit too. Still not working.
Any ideas?
Posted : 26/10/2009 12:26 pm
A common problem I think.
Most common fixes are given here - with pics:
http://www.candlepowerforums.com/vb/showthread.php?t=227518
Posted : 26/10/2009 12:38 pm
