DX light charging
[Closed] DX light charging
I have a DX light with a two pin charger, I thought I maybe able to use a shaver adaptor but the little light on the charger doesn't come on. Do I need a different adaptor or can you just cut the plug off and stick a UK one on?
Posted : 15/04/2010 8:21 pm
I just use a shaver adaptor.
Does the charger led light when you plug the battery in?
Posted : 15/04/2010 8:22 pm
I bought a american to uk plug from maplin it works.
http://www.maplin.co.uk/Module.aspx?ModuleNo=262902
I take it you have the "bastid bike light"
The plug is the charger btw
Posted : 15/04/2010 8:24 pm
Cut off plug will do.
The LED light doesn't come on no, I have two of them and neither light comes on ๐Ÿ™ could be my adaptor then...
Posted : 15/04/2010 8:27 pm
The led should come on when you connect to the battery even if it's not plugged into the mains.
Posted : 15/04/2010 8:30 pm
hmmm... no light comes on but the batteries are totally flat.
Posted : 15/04/2010 10:39 pm
My shaver adapter didn't work well, so I have a European to UK adapter from Robert Dyas. Works fine now - light is green when you connect the charger, red when charging and green when fully charged. Takes 5 hours though to charge it. You can buy a charger with a UK 3-pin plug from [url= http://www.magicshineuk.co.uk/bike-light-accessories.php?category=2 ]magicshineuk[/url]
Posted : 16/04/2010 6:54 pm
Thanks for all the pointers, turned out to be the fuse in my shaver plug all sorted...
First night ride last night, wife is new to biking but loved the night riding also!
Posted : 08/05/2010 11:08 am
