Dumbass Noob Instal...
[Closed] Dumbass Noob Installing New Chainset Question.....
Reet. Just installed, my first, chainset and BB HT2 (SLX). everything went in straight with a bit of a push. Applied a bit o' grease on the splines of the axle before pushing through. Thing is it spins as if it has a little bit of resistance on it, with and without the L/H arm fitted. Is this just how new chainsets/BBs are and just work loose over usage or have i done something wrong? There is no movement on the crank or noises.
Cheers.
Posted : 20/06/2010 6:50 pm
 ton
yes, the power from your legs wont notice the slight drag when riding.
Posted : 20/06/2010 6:51 pm
they settle in and spin a bit easier after a few rides. As long as you didn't overtighten the little plastic preloader thingy you'll be reet
Posted : 20/06/2010 7:06 pm
The preloader if just nipped up finger tight so will cane it at the weekend and see what occurs ๐Ÿ˜ˆ
Posted : 20/06/2010 7:10 pm
