dull seat clamp que...
[Closed] dull seat clamp question
[#1922805]
If my seatpost is a 27.2mm and its a on steel kona frame, what size will the seatclamp be?
29.8 or 31.8mm
thank you
Posted : 23/08/2010 1:25 pm
I'd guess 29.8, but if you can measure it with a pair of calipers to be on the safe side.
Posted : 23/08/2010 1:32 pm
I can measure it with an ikea paper tape measure. Should be accurate enough. It's just that I'm at work now and the bike is at home.
cheers
Posted : 23/08/2010 1:34 pm
Would it not be 28.6mm?
Posted : 23/08/2010 1:35 pm
 tron
I'd expect it to be a 29.8mm on a Steel frame.
27.2 post Alloy frames tend to be 31.8mm.
Posted : 23/08/2010 1:42 pm
inbreds run a 27.2 post and a 29.8 clamp
but I seem to remember having a steel Kona which ran a 28.6 clamp so it might not be so clear cut. Konas used to run 27.0 posts though...
Posted : 23/08/2010 1:48 pm
