I've always suspected that the Compression adjuster on TALAS 32's didn't do anything. Took the adjuster knobs apart yesterday to clean them and, lo and behold, it appears to be just an on-bike activity centre - a nifty clicky wheel with a charmingly made end-stop.
Well worth the money, I'll say 😉
I was hoping to find a Nick Clegg thread !!
If you cant work out what it does, should you really be taking it apart?
I presune you're looking at the blue ring one right hand leg underneath the lockout lever? If you look closer you can see that there are a number of shallow dimples of varying depth on the underside of the dial. These determine how much a sprung needle valve is inserted or withdrawn into the damping assembly.
absolutely yes
If you cant work out what it does, should you really be taking it apart?absolutely yes
Preferably with big hammer...................
How do you think anyone ever learned anything?
"i got a bit bored and seemed to have dismantled my corby trouser press"
phil 😆
poppa - MemberIf you cant work out what it does, should you really be taking it apart?
RTFM!
