DT Swiss XMM120 For...
[Closed] DT Swiss XMM120 Forks?
[#6114970]
Does anyone know if you can adjust the travel on these?
I've seen a pretty good deal on a set of them but I need some 100mm forks so was wondering if I could adjust the travel like you can with Reba's?
Posted : 14/04/2014 8:15 am
Officially NO!
Unofficially on the Single Shot - yes - (you insert a spacer on to the ABS air spring stack).
If it's Twin Shot, you can't do anything to adjust the travel.
Posted : 14/04/2014 8:49 am
Oh, that's a shame, they're Twin Shot 🙁
Posted : 14/04/2014 12:48 pm
The twin shots do have a reduced travel though - mid point on the lever is lower travel but no additional compression, far right is locked and far left is full travel standard compression. Depends if you want to run it short most of the time really. I will say my xmm is a nuisance to setup right mind, once it's set its lovely but the difference between more dive than Tom Daley and stiffer than a British upper lip is about 5 psi. They do ride firm too...
Posted : 14/04/2014 1:25 pm
