Anybody know what's happening there, only appears to have Mavic and Sun rims on there, and no hub options bar user defined or DT.
Not been there for a while after getting a couple of dodgy results. I always use Roager's calculator at the wheelpro site myself.
That's a bugger. 🙁
It seems to come and go these days... I think it must be getting updated
still having probs. with your Donkey unciy pete?
Nowt that a beating with a spirit level won't cure.Think it may be that cress aversion.
When you click user defined you enter your own dimensions which you will either have from your hub manufacturer or have measured yourself.
Same for the erto on the rim i find it works perfectly fine
I found the wheelpro came up 1mm short when i used it but the dt was fine
