Dropper Question
[Closed] Dropper Question
[#11651315]
Can I put one of these...
https://www.wiggle.co.uk/brand-x-ascend-ii-dropper-seatpost-1
On one of these.....
https://www.specialized.com/gb/en/camber-elite/p/34915?color=80302-34915&searchText=9322-5202
I’m still running a front mech on this so will need to squeeze in the shifter but that shouldn’t be to difficult. Had a chat with a mate who swears by them and the difference it makes to riding and having stalked every thread on here that seems to be the general opinion
Posted : 02/01/2021 11:46 am
Yes. You need the 30.9 mm version for your frame, obviously.
I still run 2x9 or 3x9, so I run the lever on the right, above the bars.
If you can fit a 150 mm drop version in, I would recommend that. That is 450 mm long, according to the website, compared with 400 mm for the 125 mm drop version.
Posted : 02/01/2021 12:25 pm
You can still get over the bar levers that fit with shifters.
If you are concerned about length then a oneup where you can shorten by 20mm might be an idea.
Posted : 02/01/2021 12:49 pm
You can buy the 3x shifter if you prefer that. I don't know why they don't make that an option on all the posts.
https://www.chainreactioncycles.com/brand-x-ascend-paddle-lever-kit-2x-3x-gears-/rp-prod150119
Posted : 02/01/2021 12:55 pm
Sent you a pm
Posted : 02/01/2021 3:59 pm
Just make sure you can fit enough of the post in the seat tube to get your correct saddle height. Measure how far in your existing post will go as a guide.
The external brand x would work fine for you - if you’re running a left shifter select the 2x lever to run on that side above the bars - or you could run the 1x upside down (above the bars) on the right hand side. The latter works fine but looks odd.
Posted : 02/01/2021 4:31 pm
Cheers all, I will do some measurements on the seat post and have a look at the options in the morning and probably push the button.
Box - will let you know
Posted : 02/01/2021 6:52 pm
check the insertion you have on your Seat tube as well. Kinks and pivots may get in the way! Get the longest drop that will fit definitely. I have ended up buying longer droppers for each bike as I have got used to riding with them.
If the BrandX is not available then have a look at the PNW cascade - I have one on my Cotic hardtail and it is very nicely made and you can change the drop by 30mm enabling maximum drop on the bike - Think it will be about £30 more plus the lever on top.
Posted : 02/01/2021 8:37 pm
Seat post is 320mm Not including the clamp that fixes to the seat rails and I have it 150mm proud of the seat clamp when riding. Looks like external only routing as well.
Now to find the right post
Posted : 03/01/2021 3:27 pm
