drivechain for road...
[Closed] drivechain for roadie
[#7824326]
my 105 5700 rings and cassette/chain have finally worn out......
any suggestions for decent compatible chainrings etc or should I replace like for like...I think i'll upgrade chain and cassette to ultegra and KMC
and any other roadie sites to buy them...
have checked wiggle/crc/merlin
Posted : 12/05/2016 11:48 am
 mboy
In my experience, Shimano rings tend to last longer than anything else, so just replace like for like.
Again like for like on the cassette.
I always use KMC chains though, find they last longer than Shimano or SRAM and the quick link is better than SRAM's use once affair, or Shimano's dedicated pin.
Posted : 12/05/2016 11:50 am
Ultegra chains and cassettes are a worthwhile upgrade - they don't cost the earth and they save a fair bit of weight.
It's often cheaper to get a full chainset as you get a bottom bracket too, the shops you mention will be your best bet but Ribble might be worth a look too.
thought so...cheers!
total geek when it comes to mtb stuff, but I know next to nowt when it comes to the roadie..it just gets ridden washed and forgot about as nothing ever goes wrong!
Posted : 12/05/2016 11:56 am
Not necessarily. I replaced everything recently, and most chainsets didn't include BB (contrary to relatively recent MTB purchases). I was pleased that the 105/Ultegra BB was cheaper than the Tiagra on the site I used...
Posted : 12/05/2016 11:59 am
I haven't checked but High on Bikes and Winstaneys are also worth a gliff.
Posted : 12/05/2016 12:18 pm
Shimano mtb chainset usually come with bb but their road ones don't. If you have 11 speed compatible wheels then 11 speed 105 is excellent.
Posted : 12/05/2016 12:25 pm
Decent chainrings from TA - hardened alloy last longer than stock Shimano IME. Ultegra cassette is lighter, shinier but don't expect it to last longer. KMC X-series chains with gold ti-Nitride finish run smooth and wear well if you keep them clean/lubed
Posted : 12/05/2016 12:27 pm
What else needs replacing 5700 is a bit old now ? Cables, Jokey Wheels... the list will go on... what does that come to?
5800 groupsets are £270, i'm sure you can off load the old groupset as "spares" for about £50 and you find you won't have spent much more.
Posted : 12/05/2016 12:38 pm
Out of interest, do you know roughly how many cassettes you've got through on those chain rings?
Posted : 12/05/2016 12:55 pm
On sale at [url= https://www.merlincycles.com/shimano-105-5700-chainset-black-49195.html ]Merlin[/url]... No BB unfortunately...
Posted : 12/05/2016 12:57 pm
pleader, all original. didn't check chain until too late so left it all to wear out at same rate...
@tod yes new cables and jockey wheels too....
it will start to add up...
hmm wonder if my hub is 11sp compatible.....new shiny stuff is ace!
Posted : 12/05/2016 1:08 pm
Dont think my hub is 11 speed compatible...boo
Posted : 12/05/2016 1:42 pm
new wheels too .... yah!
Posted : 12/05/2016 1:43 pm
Just been through this. I replaced a 5700 chainset wtih a 5800 from wiggle. Its eleven speed but no problem with 10sp drive train, cheaper than 5700 and much better looking, stiffer etc. The internet recommended i use an 11sp chain and this has been absolutely fine with 10sp cassette
If you do want to get a whole groupset, you can keep the wheels, just take out one of the cogs - either the 13 or 14t - and put the spacer on the freehub first. Same width as 10sp cassette, but right spacing for 11sp shifters.
Posted : 12/05/2016 3:31 pm
 Haze
TA
Have these on my turbo/winter bike, lasting very well indeed.
Think I may have a brand new set of 5700 rings at home doing nothing, probably 50/34...can check later if you're interested?
Posted : 12/05/2016 4:38 pm
@lodger thanks for the info
@Haze yes mate I'd be interested if I go for just changing rings etc....bung me an email to discuss if you like...
Posted : 12/05/2016 4:49 pm
Hasn't your chain been slipping for ages then? I tend to wear my chain and cassettes out together, and change them when they start slipping after 2000-3000km, and I haven't yet needed to replace chain rings on bikes that are on their third cassette. Can't imagine there would be any chain left by the time it had worn out a set of chain rings.
Posted : 12/05/2016 4:56 pm
is slipping pretty badly now! so though it best just to replace the lot in oone go as they are looking fairly shark toothy now
Posted : 12/05/2016 5:23 pm
I would be surprised if replacing the chain rings was really necessary, when I was wondering whether to replace mine recently general consensus seemed to be 15,000-25,000km on a set of chain rings, mine had only done about 8000km, looked a bit shark toothed, but I think that's just tooth shaping to help shifting, so I just changed cassette and chain and it's all working fine.
Might be worth trying just a new chain and cassette before you spend a load on new rings, unless you've been doing some mega mileage?
Posted : 12/05/2016 6:15 pm
theyve been for 3 years now 😳
Posted : 12/05/2016 10:46 pm
