Double Bash - sizin...
[Closed] Double Bash - sizing question
I can't decide between 24,36 or 22,32 ? ๐Ÿ˜
Posted : 06/06/2010 5:21 pm
22,36 ? ๐Ÿ˜‰
Posted : 06/06/2010 5:22 pm
22/32 works fine for me but I tend not to go so fast on the downs as I like to conserve my energy ๐Ÿ˜›
Posted : 06/06/2010 5:23 pm
22 36 here. Good combo.
Posted : 06/06/2010 5:24 pm
 mboy
You'll be glad of the 36 on bigger, longer, more open and flowing rides where you'd normally end up in your 44T big ring from time to time. With a 36T you effectively only lose the top 2 gears from a full triple ring setup, with a 32T ring you lose another gear too.
24/36 setup on one of my bikes, with an 11-32T cassette, can't say I've ever found that I wanted a 22T ring instead, even going up the steep climbs at Afan and Cwm Carn.
Posted : 06/06/2010 5:25 pm
 thv3
24/36 Here, works well for me.
Still keeps your top end speed and can't say I have noticed a "loss" of the lower gear
Posted : 06/06/2010 5:28 pm
OK cheers, so are the bash guards identical either way?
If they are identical then I guess it would make sense ordering a 24,36 now and then changing the smaller ring later on down the line if I really miss the easiest gears?
Posted : 06/06/2010 5:30 pm
24/36 For me too
Never left wanting
Posted : 06/06/2010 6:05 pm
22/36 is the standard answer. I ran with 22/32 for a while and I did miss the highest gears a little, 22/36 gives a really nice range of ratios.
Posted : 06/06/2010 6:08 pm
 StuE
24/34 on one bike 22/34 on 2 others works for me
Posted : 06/06/2010 6:18 pm
