Does this sound lik...
[Closed] Does this sound like a hub issue??
Fitted some new tyres on the full-suss MTB last week which are a slightly larger diameter than the old ones - nothing major, and still plenty of clearance.
Noticed that occasionally the rear was making a noise that immediately sounded like the tyres were rubbing on the frame.
However.
a) The tyres are muddy, and there was nowhere on the tyre that was free of mud / indicated that the tyre had been rubbing anywhere.
b) There was no relation to the noise happenning when the suspension was compressed - which I'm assuming would be the most likely time for the tyres to be rubbing.
c) The noise only occurs when I am freewheeling and stops when pedalling. For instance I was able to get the noise relatively easily when freewheeling on the road back to the pub - i.e. suspension not in compression at all.
Does this sound like a hub issue? Never had an issue with any hubs to know how it manifests..
Posted : 04/06/2018 10:36 am
Probably your freehub bearings on their way out. Depends on the type of hub as to what the fix is, but most are easy enough to sort out.
Posted : 04/06/2018 6:51 pm
