Do SRAM / Shimano d...
[Closed] Do SRAM / Shimano do a 38 tooth chainring
[#1926083]
I cant find one anywhere but am getting chainsuck on my 26/38 and think it could be my DMR shiftR chainring. It needs to be ramped and pinned. 🙂
Posted : 24/08/2010 10:53 am
Yeah, I've got a "XT" 38tooth, it comes with their touring XT chainset, I say "XT" as it doesn't look anything like the XT on my other bike i.e. its grey not black and doesn't have holes drilled in each tooth!
Should be able to pick one up from your LBS.;
Posted : 24/08/2010 11:03 am
What do you use it for? I am looking to add it to a double with bash setup. I found this but not sure if it is ramped an pinned or set up for DH single ring: http://www.chainreactioncycles.com/Models.aspx?ModelID=27683
Posted : 24/08/2010 11:08 am
I just use mine for a 1x9 set up, however it came from a tripple ring set up so sure th ramps and pins are fine if I had more than one ring!
Posted : 24/08/2010 11:15 am
Are you sure that is a 38T Steve? I reckon it should be a 36T as XT touring rings are 26/36/48 sizes.
Posted : 24/08/2010 11:48 am
Still looking... really don't want to go to 36 as 38 is the magic ratio for me.
Posted : 24/08/2010 12:09 pm
There is an Alivio level M411 ring in 4 bolt 104bcd 38T.
http://www.cyclestore.co.uk/productDetails.asp?productID=16355
Posted : 24/08/2010 12:15 pm
