Is there a difference between the two??
I can't see any 2012 RS revs with blackbox and am looking to get a set of RLTs
Ta
Will
Couldn't see owt meself either. MoCo DNA seems to feature across the whole range from RL upto the Worldcups. Seems to feature dual flow rebound and compression like blackbox too. No more blackbox Revs it appears for now.
It is all a bit low key this year but I read the RS mediabook and was convinced enough to go for some 2012 RLT's and they ride as well as if not better than my 2011 RLT Ti's with Blackbox.
I think the Revs have all been aligned in terms of damping and as you go up the range you just get greater levels of adjustment/lockout/remote lockout etc (and of course carbon crown/steerers). Which if like me your not fussed about makes the RL's and RLT's great value.
The sectors seem to now have the slightly older/cheaper but perfectly fine damping and hence fill the more budget end of the 150mm travel fork market.
