DMR Deathgrip Probl...
[Closed] DMR Deathgrip Problems
[#9885132]
Hi guys,
Just after a bit of user experience. My deathgrips today felt as though they they were moving on the bar a bit. Must of been only about 5mm but very disconcerting.  Has anyone else experienced this? Must only be about 3 rides old as well.
Posted : 10/03/2018 9:10 pm
Have you got them fitted properly i.e. right on to the bar?
A friend of mine thought his was on properly but it ended up coming off mid ride. Think it took a fair amount of force to get it right onto the bar.
Posted : 10/03/2018 9:12 pm
Yep they are right on.
Posted : 10/03/2018 9:15 pm
I thought mine were right on, and then I hit the end with a rubber mallet to be sure. They still had another 5-10mm to go. Worth a try. Im on my 4th set on 3 different bikes and haven’t experienced any movement.
Posted : 10/03/2018 9:22 pm
Three pairs on three bikes and no such issues
Posted : 10/03/2018 9:26 pm
+1 for the rubber mallet. They deffo need a good whack to get in place. Great grips.
Posted : 10/03/2018 9:54 pm
I bashed the ends of them when i installed then to make sure they were on. Checked the lockrings were tight too. First two rides were fine but a wet one today and they start slipping.
Posted : 10/03/2018 10:04 pm
When you say slipping do you mean torsional movement along their length ie one end fixed the other end rotating or is the whole grip moving?
Posted : 10/03/2018 11:02 pm
The whole grip moves but you mainly notice it at the end of the bar.
Posted : 10/03/2018 11:48 pm
