DIY lights - best d...
[Closed] DIY lights - best driver?
[#4372511]
I have a couple of LEDs and lenses lying around for tinkering with over the winter. Is the b3flex still a good bet for running them? I think that is what Trout used in his. The drivers works out about £25 each, which does seem a bit steep (LEDs were only £4, lens £2). The LEDs want 1500mA, and it would be nice to have all the functionality of the bflex.
Posted : 17/09/2012 8:56 pm
Mowgli
there are cheaper drivers on the market but the Taskled Flexs are the dogs do da`s for sure.
depending on what battery voltage you want to run off
2 leds in series off a 7.4 volt battery then an Lflex would be the driver
your 2 leds in series but off a > 9 volt battery the the B3flex would be good or even the B2flex
I do have all three drivers in stock
the B2flex will do your 1500 ma leds the full juice while the B3flex will go up to 3 amps
Posted : 17/09/2012 9:12 pm
Hi Trout,
The LEDs I have actually have four XP-G (or XP-E?) each (I want to make two lights), and my battery is 14.8V. How much for the different drivers? Is the B2flex any cheaper than B3flex?
edit: these bad boys [url= http://www.led-tech.de/en/High-Power-LEDs-Cree/CREE-Solutions/4-x-CREE-XP-G-R5-on-23mm-star-PCB-LT-1852_120_117.html ]http://www.led-tech.de/en/High-Power-LEDs-Cree/CREE-Solutions/4-x-CREE-XP-G-R5-on-23mm-star-PCB-LT-1852_120_117.html[/url]
Posted : 17/09/2012 9:16 pm
The B2flex is just the job for your set up
however as your battery drops in voltage the driver will go out of regulation and the leds dim a little and you wont have all the light levels available .
this is not a bad thing you could look on it a a reserve tank
no harm will come to the lights .
yes will do the B2flex for £20 each
Posted : 17/09/2012 9:24 pm
Mowgli
If you are only wanting basic control of off, mid, high then i got a buck driver from blackcattech's ebay page, i can't find it just now but trout will know who i mean and may be able to pass on contact details. I was used a year or so back in a Lumicycle halogen to LED conversion. They are cheaper controllers if you can get hold of them but also lack some of the fancy programmable functions the TaskLED boards have.
Posted : 17/09/2012 9:25 pm
Troutie
do you have any of those LED drop ins left for the Lumi halogen units?
paul
Posted : 17/09/2012 9:51 pm
Trout, is your email still the blueyonder one? You have mail.
Posted : 18/09/2012 11:04 am
Yes same email Gareth and you have a reply 🙂
Speshpaul I have some of the heatsinks plus some triple led boards
non of the optics though can get some when i get home from hols end of sept.
Posted : 18/09/2012 11:38 am
#slight hijack#
trout, if you have any more lumicycle conversion stuff, i would be very interested. Found an old halogen lumicycle light in a box the other night - thinking of superchargin it...
Posted : 18/09/2012 11:55 am
