I'm thinking of refreshing my Klein with a set of disc wheels and brakes. I have a post mount on the rear chain stay with bolt holes approx 22mm apart.
Can anyone advise where I can get a mount from to allow me to put either formula's or shimano disc brakes on?
TIA
Have a '99 Klein here and I looked into this, you have got a 22mm hayes mount on the frame. Not sure whether adapters will still be available retail but someone may have a 22mm to IS or Postmount laying around.
I decided against it in the end as I was advised that the small rear facing dropouts often allowed the wheel to eject when disc brakes wear heavily applied.
This is what you need
http://www.allterraincycles.co.uk/product/118223.html
You may need to fit a larger disc for clearance.
No problems on my Klein with rear facing dropout.
