8 seconds was enough to win the tour de France in 1989 🙂
Lots of (Belgian pro) crossers are still using canti, watch this years world champs for example.
They will start to be used but it's not the biggest deal in the pro ranks at the moment
edhornby - Member
8 seconds was enough to win the tour de France in 1989Lots of (Belgian pro) crossers are still using canti, watch this years world champs for example.
POSTED 29 MINUTES AGO # REPORT-POST
LeMond won the 1989 Tour because he used aerobars in the final Time Trial .
The point is that there will have to be a total adoption of disc brakes in the pro peloton because of neutral service needing to have a standard wheel , axle type and disc size .
[quote=IdleJon ]
- nobody is suggesting disc brakes will result in bikes sliding all over the road
Well, this seems to be saying that:
Really? I've snipped the relevant bit, try re-reading...
wet or dry, with good calipers you can alredy easily overwhelm the available grip from a road tyre, and then youre sliding.
I've been running a pair of Avid Juicy Ultimates (were cheap at the time) since 2007 on my Roadrat with no problems with either corrosion or unwanted locking and it's mainly used as my winter road bike.
[quote=Ramsey Neil ]Depends how you look at it Mark Cavendish has won plenty of races and I would suggest that all of his Professional wins have been when he's been sat in the peloton from the start to less than 1KM from the finish .
Yes, and in which bit of the race does he earn his money? I'm not sure you're reinforcing your point that much by pointing out that the bit where discs are irrelevant to performance is irrelevant to the result of the race.
I'm sure Cavendish will be an early adopter of discs, given how important braking is to his performance. 8s in 40km translates to 0.02s in 100m. At 60km/h you cover 33cm, or about half a wheel in 0.02s.
I don't know if there is a standard now? I assume everyone runs 11 speed these days but is campag compatible with sram/shimano? They already carry different sized bikes don't they?
Isn't cav wearing an aero helmet? I know he occasionally wears a skinsuit. He does care about aero as he wants to get to the line as fresh as possible. HE also has to survive the rest of the race such as mountains, chasing back on with a puncture, cross winds etc.
Road racing will be great now. Its been utter pants until now, but im worried my jaw will be harmed hitting the floor when i witness the awesome vision of race bikes with discs in action. The one day classics will be so much better. And i might even go and watch the tour live the year they're sanctioned the records book writers will be proper busy. I'm so excited.
interested in what you consider to be the main advantage of Vs if it wasn't power.though in reality ultimate braking power wasn't the main advantage
Ease of setup was nice, (less mud clearance was a disadvantage) but moar POWER! was the big thing for me.
Yes. Even in the days when Campag/Shimano 8/9/10 speed weren't properly compatible riders just made do when necessary. That's obviously much harder with a disc that's rubbing...
It'll happen and it'll happen across the board - there are all sorts of ways of mitigating the issues (solid discs for example, maybe with a CF centre). And aero, etc will develop once they're being used and can deviate away from mtb designs (see Shimano's new disc 'standard'....)
Shut up will you about Discs on Roadies, you are disturbing me. 😕
