Dialled Bikes Alpin...
[Closed] Dialled Bikes Alpine finished at last - Piccie
Just fitted the brakes,
just need to try it out now.
Might try it on the 'ice cream run' at Rivvy this afternoon
Posted : 30/05/2009 10:47 am
Nice, just in the process of building mine up too ๐Ÿ˜€
Posted : 30/05/2009 3:20 pm
nice, one of the best i've seen so far, dunno why, just looks 'right' and well balanced
Posted : 30/05/2009 3:28 pm
Just had a ride round the block and I must say it's bloody slack!!!!
Not sure if it's going to be great at tight twisty singletrack, but i bet it is when it gets fast and steep. Well that's what i'm hoping for anyway
Posted : 30/05/2009 3:29 pm
Was just thinking how super slack that looks. What's the a/c on those forks?
Posted : 30/05/2009 3:39 pm
They are set at about 150mm so should be 545mm I think. At 170mm the head angle is 64.5 deg!!!
I think the fact that it is a small/short frame affects the 'look' of the thing
Posted : 30/05/2009 3:43 pm
 ash
[i]They are set at about 150mm so should be 545mm I think. At 170mm the head angle is 64.5 deg!![/i]
you sure about that? I thought it was 67 degrees with 160-ish mm fork...
[i]Not sure if it's going to be great at tight twisty singletrack[/i]
reduce the front travel and the Alpine is great on the flat
Posted : 30/05/2009 8:25 pm
... or run the fork with a bit more sag. Mine's not bad at all at woodsy ST, but it's better at all the way up and all the way down. Contrary to what some say I think it's a great climbing bike.
Posted : 30/05/2009 8:35 pm
Swayndo - Member
Posted 49 minutes ago # Report-Post
Seconded. Just sit back and spin up the back wheel.
Posted : 30/05/2009 9:26 pm
Intend to run it at about 150mm most of the time, but need to ride it a few times to get it sorted.
Certainly needs a longer stem being a 15"/21"TT. It's got a 50mm on at the moment which makes it feel VERY short even for a short arse like me.
Posted : 30/05/2009 9:51 pm
