Deviate Highlander ...
Deviate Highlander 2 grease ports
[#13535183]
Afternoon, any Highlander 2 owners on here who've bought a non-Deviate branded grease gun for the ports? Any recommendations?
Thanks
Dan
Posted : 18/04/2026 3:03 pm
You want a narrow needle grease gun to engage correctly with the zerks nipples. The watch out is that you want one with a long needle as some of the nipples are inside the bolts/axles at the bottom of the hex key recess. You can get away without the bent tip that the Deviate one has, it just makes access a little easier in some places.
This motorex gun would work but is spenny:
https://slam69.co.uk/products/motorex-bike-grease-gun
This one would be ok for the external nipples but its probably too fat for the ones in axles:
https://www.richardsonsonline.co.uk/Catalogue/Maintenance/Cleaning-Lubrication/Grease/Weldtite-TF2-Grease-Gun-WGG
Posted : 18/04/2026 10:22 pm
