My what alot of photos of ham fisted monkeypaws mechanics foopas you have posted there klunk.
If this wasn't the case then where are the numerous posts about faulty Thomson components?
Because they make so many items with moving parts and things that can wear out...
Apart from their relatively new dropper (compared to many Hope products), Thomson don’t make components with movable parts or bearings that are subject to the same levels of attritional wear – so not a particularly useful comparison.
EDIT - as cgguru posted moments before.
see what happens if you do the a google image search with [url= https://www.google.co.uk/search?q=cracked+hope+stem&biw=1233&bih=830&source=lnms&tbm=isch&sa=X&ei=kgWxVNaKH8fkaPepgqAM&ved=0CAcQ_AUoAg ]"cracked hope stem"[/url]
Still going christ. Im sure it would have been easier to get a reply from hope from the start rather than an independent forum
Btw samsung why has my phone battery died after 14 months ???
2 hope stems on that page klunk....both with similar failure modes in flexure points when pinch bolt clamps are done up- at a guess to more than 5nm
None of my 3 Hope components which broke had moving parts.
