killed my rear hub at black rocks last night, I'm looking at replacing it with something cooler and serviceable but getting lost with all the different sizes and types etc, it's got fm-rh66 on it, standard cube 2012 acid wheel, please help cheers
get a Hope pro2 evo rear hub, adaptable to most hub sizes and fully serviceable, all your future woes will dissapear... along with a small chunk of cash from your pocket!, but they are worth it 🙂
Hope Pro II, will last forever (if not call hope for a new one)
hope pro 2 are the most irritating hub on the planet, it was a blessing when I changed my bike and got silent hubs back.
are superstar any good half the price of hope
I very nearly went for SS switch evo hubs as they are cheaper and do look to be of decent quality. but have always wanted Hope so saved up for a bit longer. and they are british designed and made which makes me happy.
but walker's dont get out of your way with silent hubs, they do with the racket hopes make 🙂
What did you kill on your shimano hub and what part of it can you not service that you need to?
As barrykellet says, what have you done? If you'craked it, then you're buggered, but everything else is replaceable and easy to replace at that. Not sure what hub it is, probably deore or one of the "none series" models. Whichever it is, you should be able to get spares.
My favourite is Dt 240s
all I know is the cassette spins freely both ways, so no drive, I was under the impression shimano hubs once broke have to be replaced
[url= http://cycle.shimano-eu.com/publish/content/global_cycle/en/nl/index/components/mountain/acera_9-speed/product.-code-FH-RM66.-type-%7Cfh_mountain%7C.html ]this is my hub, if I can just stick New innards in it the I'm happy [/url]
Sounds like you only need a new freehub although these cost almost the same as the hub you won't need to re-build the wheel.
Just buy a complete hub and strip it of hub body comes and axle
Mostly cheaper than buying the bits as spares
The part the cassette goes in is called the ' free hub body'
And just bolts onto the main hub shell
Normaly about 15-25 but do vary with hub model
Ah just replace it, you'll get better pick up as well. My bike came with a cheap non series shimano hub, I replaced it with a SLX hub - much nicer (but I like shimano hubs) I would recommend getting a hope, unless you have a fetish for cup and cone there really is little point in getting anything else.
You could try removing the cassette and squirting loads of GT85 / WD40 into the freehub part as best you can and see if you can get the engagement back. Chances are there's just a build up of muck in there sticking the pawls.
If this is a success get some spray grease and do the same thing again.
My freehub has been going over 3 years and circa 1000 miles since doing this.
Worth a try!
this hub has done 1500 miles in 8
months, and it's all been pretty tough going,
So?? Still worth a try isn't it?
tis but a baby in hub terms....
Looking over at my original Hope ProII from about 06. You can keep throwing new bits inside a shimano hub if you want. Probably also depends on the state of the rim too.
You can put a new freehub body on it, but i'm pretty sure it's not the "normal" type on that hub,with a different spline attachment to the hub body. Probably best to strip it, and take it to your LBS as a pattern, and as said above, may be better to buy a complete hub and change the axle and bearings too.
I've just done the freehub on my SS. An £8 donor hub from CRC and my old Deore hub now has new freehub, axle, cones & balls.
Runs like new.
The original hub is from 2003...
