Daft seatpost clamp...
[Closed] Daft seatpost clamp question
Hello - short and no doubt stupid question: if I have a 27.2 mm seatpost, will the Hope 28.6 mm clamp fit? (They don't have anything smaller, and I'm guessing the clamp needs to be a little bigger than the post).
Thanks in advance.
Posted : 19/03/2011 2:51 pm
Don't think so,you'll need a 32mm clamp.
Posted : 19/03/2011 2:55 pm
Best to measure your frame.
An aluminium frame will have thicker walled tubes than a steel one for example, so will use a bigger clamp for the same size seat post.
Posted : 19/03/2011 2:57 pm
Depends what frame it is, we have three bikes with 27.2 posts, all use a different size clamp
Balls ๐Ÿ™
Surely this should just be easy to cope with numpties like me.
Posted : 19/03/2011 2:59 pm
What bike is it?
Posted : 19/03/2011 3:01 pm
Genesis Altitude 20 aka 'The Winter Mud Bike'.
This spec - http://www.evanscycles.com/products/genesis/altitude-20-2009-mountain-bike-ec017156
Posted : 19/03/2011 3:06 pm
Steel frame I would say somewhere around 30mm. Have you checked to see if the size has been stamped on the clamp, sometimes on the inside?
Posted : 19/03/2011 3:12 pm
Hi Craig - blooming good idea, but just checked and nada. Thanks though!
Posted : 19/03/2011 3:19 pm
A quick google suggests it's 30.
Posted : 19/03/2011 3:23 pm
Thank you Khani.
Posted : 19/03/2011 7:33 pm
