Daft question, repl...
[Closed] Daft question, replacement O ring to show sag on rear shock.
[#4830535]
Just realised that my new Fox shock doesn't have an O ring on the shaft to show how much travel I'm getting.
What would be a suitable replacement that I could fit without unbolting one end of the shock?
I need something that I can attach round the shock that won't get in the way or look too stupid.
The problem with something like an elastic band is that it will have to have a knot and will look weird...
Any ideas?
Posted : 03/02/2013 8:26 pm
zip-tie.
Posted : 03/02/2013 8:31 pm
a 2.5mm zip tie. Get the tension right & cut off the end. I have seen them on forks & they look OK. You could even get a red on - like the O ring.
I have put an O ring on in the past to replace lost ones on a rear shock but the one I used (gen purpose one?) tended to disolve a bit with the fork lube I put on my stanchion (shaft).
Posted : 03/02/2013 8:36 pm
I wouldn't bung a zip tie on, too scratchy. Loads of O rings on ebay.
Posted : 03/02/2013 8:43 pm
? could you use elastric string (like used inside tent poles) - so you can just tie it round
Posted : 03/02/2013 8:45 pm
I was worried about the scratchyness of a ziptie. Might try thin elastic.
Posted : 03/02/2013 10:22 pm
You can buy a box full in Aldi for £6.50 !..
Posted : 03/02/2013 10:27 pm
Assuming you are fastidiously following the maintenance schedules and doing an aircan service every ten minutes, then a spare 'O' ring comes in the seal kit.
I know this because after doing the service on my shock for the first time I had one 'O' ring left over, and after much head scratching and pouring over maintenance manuals, and when I was just about to take the whole bloomin thing apart again, I realised it was that one 😳
Posted : 04/02/2013 1:52 am
If your shock can be damaged by a bit of nylon, it might not stand up too well to mountain biking...
Posted : 04/02/2013 1:59 am
Just use the dirt left on the fork as measurement 😆
Posted : 04/02/2013 2:04 am
Do it right, o-ring and just unbolt the end? There's very few bikes where that's problematic.
Posted : 04/02/2013 2:11 am
Zip tie will slide and scratch, o-ring will roll. You can use zip tie to set sag, just remove before riding.
Posted : 04/02/2013 9:06 am
Halfords do a little selection pack of various sizes in the car parts department for a coupe of quid.
Posted : 04/02/2013 8:54 pm
